ChaosJohn
I'm trying to un-invert a Sanyo 20EZ monitor with the Bob Roberts kit. It has the standard instructions you see everywhere, which mostly involves adding components to empty spots on the chassis.
One of the resistors you're supposed to add is R203. R203 is printed on the front of the chassis, but not on the back. And even on the front, the place they printed it isn't very indicative of where the actual holes are where the resistor will go.
See the attached pictures - the two blue transistors are R201 and R202, and note that they're screened right between the two holes where the transistor gets added, but R203 has no holes to the right or left of it. Could it be the line near the bottom of the IC box area above J1 and below J2?
