Where do you hook up the sync's on a Jrok board?
Shawn1976
Donor 10 years: 2016-2025
Saint Augustine, Florida
I have a Jrok Multi-williams PCB and was wondering how the sync is connected to the PCB?
Can you hook the PCB sync through the jamma harness or do you need to hook the sync through the PCB connection?
Clerification would be helpful.
The JAMMA connector outputs negative composite sync, of course. There is a header on the board that has separate H and V sync, if you need/want to hook your monitor up that way.
Ok. Cool.
Wanted to ask too is the board just hooked through just the 3 pin of the monitor chassie or does it need to be hooked through the 2 and 3 pin and looped through the connector?
