Where do these wires go??
caddysrule
Tracy, California
I can find a manual please tell me where these go...
Where do the extra black brown and white wires go??
you should have red, green, blue, bare wire is ground, then horz or vert sync on the little 3 pin molex depending on your game
probably need some crimp molex pins for a permanent fix
One should be your BLUE.
One should be your GROUND.
One should be your SYNC. (H sync)
But can't tell you which is which without knowing what they are coming from. (color codes wise)
If I had to guess..... brown would be your BLUE, black would be your GROUND, white would be your sync.
I would try the GROUND and H Sync on the three pin connector first.
Blue only has one place it can go.
EDIT: Oh yeah, that is a bare wire isn't it? Hmmm, knowing the source would indeed help.
