Where can I get offset cams and lock?
i86time
Riverside, California
Offset cams are driving me nucking futz. Out of the 7 games I have, only two came with a full/correct set of cams for all of the locks. Problem is, I can't find the correct offset cams for the remaining locks. For example, my TRON that has a correct set has a 7/8" lock for the back with an ~ 1/2" offset. See below:
It needs that long cam and offset to compensate for the plate/screws that prevents the whole lock mechanism from turning.
The coin door lock is 5/8" with an ~ 1/2" "bent" offset. This setup works, but it's very tight (I can feel it rubbing the metal stop when turning the lock).
Where can I get extras of these (and a more correct non bent cam with a step 1/2" offset)? I don't think Bob Roberts sells 1/2" offset cams and the largest offset on the Happ site is 3/8". The cam length on the TRON back door is 2". If I use a straight cam on a 7/8" back door lock it won't work because it'll get hung up on the screw. If I use a straight cam on a 1 1/8" lock, there's too much slop in the door.
Finally, I need this kind of lock for a separate lock box. I'm not really sure what it's called.
Pull the lock, head to a Locksmith
Why not pull the lock and take it to a locksmith, who can re-key the lock to your desires? Many good arcade locks can be re-keyed or even have a key made by a good locksmith.
If they are all the same brand, you may be able to get them all keyed alike.
I'm not a locksmith, and don't play one on TV. (e.g., I have no financial interest).
Otherwise, look at the end, and find a similar lock. Pinball Resource and Marco Specialty have locks, to name a few. Otherwise, you should be able to hit HAPP/SUZO. They have tons, but they tend to be expensive.
If you find a source please post it here. I need a couple of those offset cams as well and one of those large mechs like you pictured also.
Mitch
EDIT: Aside from the funky lock in the bottom pciture, I actually only need the proper offset cams, not the locks.
Mitch
I'm hoping someone here has a source for these. I've seen offset cams included in some of the lock sets @ Lowe's/HD, but none are long enough for the back door. I'd like to be able to buy them without having to buy the whole lock set, especially since I can get the locks cheaper from folks here.
yes but they are no help
Most arcade game and pinball locks are made by Fort Lock:
http://compx.com/products-fort.html
you can't buy direct and all they will do is give you a distributor listing, I even inquired to be a distributor and they said they were not interested in any more distributors. They even told me to go see a lock smith even no I was trying to buy a large quantity of locks. I have been buying them from betson and have over 50 keyed alike locks when I went to buy another 50 they literally doubled the price for them so I was interested in becoming a distributor to buy the locks for myself as well as sell here. They are hands down the best lock though :( makes me sad how they were so rude and unhelpful.
customer service sucks
I identified the lock for you…we sell through wholesalers/distributors only. You can contact one of them, but they most likely will direct you to one on their resellers.
Clark Security Products 800.542.5625
Lou Galvao
Phone: 864.297.6655
Sent: Monday, July 09, 2012 10:58 AM
To: Lou Galvao
Subject: Re: CompX Fort web contact
Thanks for wasting my time why did I send you pictures.
In a message dated 7/9/2012 4:54:06 A.M. Pacific Daylight Time, [email protected] writes:
I recommend you contact a few locksmiths in your area, preferably a full service locksmith.
Lou Galvao
Phone: 864.297.6655
Sent: Monday, July 09, 2012 1:11 AM
To: Lou Galvao
Can you please tell me where to get these?
In a message dated 6/26/2012 2:39:55 P.M. Pacific Daylight Time, [email protected] writes:
Looks like MFW29000 series…see attached. Thanks.
Lou Galvao
Phone: 864.297.6655
Sent: Monday, June 25, 2012 5:44 PM
To: Lou Galvao
Let me know if this picture is good enough.
In a message dated 6/25/2012 2:25:52 P.M. Pacific Daylight Time, [email protected] writes:
Please send me a photo or two...I will direct you to current distribution; we are not looking to add to our distribution channel.
Thank you for contacting CompX Security Products.
Lou Galvao
864-297-6655
-----Original Message-----
Received: Thursday, 21 Jun 2012, 10:21am
To: [email protected] [[email protected]]
Subject: CompX Fort web contact
Below is the result of the CompX website contact form.
on Thursday, June 21, 2012 at 12:21:39
Comments: I'm trying to identify a lock made by fort lock, on the key it's stamped 750xxx W18 on the lock the only mark is 752. Could you help me identify it, I can send a picture if it would help. Also do you sell direct or what does it take to become a distributor.
submit: Submit
There's actually a distributor near me (well, about 25 mi one way). I just need to check the CompX catalog to see if they make the cam I need. I can imagine needing to buy a box of 50 or so, though.
I have no idea why these offset cams aren't more widely available. If I have the time this weekend, I might check out an Ace and a couple mom & pop shops to see if they have any. What the hell did people do with these when they pulled them off the doors?
I suppose if it came down to it I could somehow affix a 1/2" plastic/wood/metal piece to the door the make up the difference.
we are neighbors
we are neighbors, what distributor is that?
According to the CompX site, its:
Name : AUSTIN HARDWARE & SUPPLY, INC.
Address 1 : 3323 GRAPEVINE STREET
Address 2 :
City : MIRA LOMA State : CA Zip : 91752
Phone : 816 246 2806
