You would not need to replace the entire thing. Check the plunger to see if it moves freely through the coil. If it is too tight due to roughness or wear then replace the sleeve. That will allow the plunger to move more freely making harder hits. Next thing would be the coil which is still much cheaper than an entire knocker unit.
BTW...this is posted in the wrong place as it isn't something for sale.
