kerri369
although i feel awful about a damaged game in transit.......listen to this tale. saturday i went into my basement (another rain storm) i saw water on the floor but that water was not coming from the walls, it was pouring in from my breaker box! little did i know the outside service line was split funnelling water into my panel. i had an electrician come and eventually replace and upgrade my entire electrical service inside and out....then when they went to hook up the ground we realized i had a watermain leak! then the water department showed up and the valve blew off the pipe sending water everywhere! then the truck i use for work caught fire! the plumbers got the water under control finally friday! so all in all it was a pretty fucked up week!!! the good news is my games were ok and they are now wired seperately with thier own switch panel on the cieling and a surge protector installed directly into the breaker panel!!!! so when you think life is bad, look around someone else has it worse!!
