What's wrong with these pictures?
mcwagner10
California
I got my Beatmania/Hiphopmania Complete Mix 2 Cabinet yesterday, and everything works great except for the turn tables. My guess is that something is simply not connected, but I don't have enough hardware knowledge to determine what it is. Can anyone tell me if the connections show in the 3rd and 4th picture are correct?
One suspicious thing: Notice picture 4 (which is the right turntable) has a green wire, while the other doesn't. Even such, neither work.
Please help!
green wire+ground
The green wire is a ground wire and it needs to be attached to ground... that might not solve your problem but it might as the controls wont work if not grounded.
looks like it needs to connect to other turntable... check wiring schematics if you have them or just try hooking one of the terminals try the same one its connected to on the other turntable first
