What's this weird interference on my k7400?
action53
West Columbia, South Carolina
It was crystal clear then the power supply died and I replaced it with a switcher. I zip tied the monitor power wire to the frame so it didn't pull on the chassis, could that be causing it? It's slightly wavy.
attachment.php
did you ground the switcher and is the AC coming from cabinet AC or off the same source as the monitor.
The switcher is grounded and the monitor comes from the same source. The ac for the monitor goes though that silver thing, I think. Should I run a ground from the switcher to the frame of the monitor?
your ground on the switcher should be attached to the green ground wire that goes out the plug to your wall outlet. be sure you haven't created a ground loop which can cause interference.
So jump green ground to black ground? I have green ground connected to the bottom and black ground connected to the top.
FG ground is the earth ground for the AC line voltage and the GND1 and GND2 are the DC voltage ground. they do not get hooked together.
post a picture where the Green ground wire is hooked to in your cabinet.
have you checked your line filter?
if you have an isolation transformer, that will cause this. for whatever reason monitors that don't need them have this happen.
a factory mod that Williams/Midway used was a wire to bridge between earth ground and logic ground. this is if you wish to maintain earth ground to your monitor -- you could alternatively de-pin the monitor power plug or snip the wire in a convenient spot. I was previously anti-earth ground to the monitor but I saw a post here a few months back that was pretty enlightening as to why that's not always the brightest idea. :p
I'll try bypassing the isolation transformer and then un earth grounding the monitor and see if that changes anything. It just blows my mind because the picture was clear with the computer power supply in it and I wired the switcher exactly the same.
I've run into this before with cheap switchers. Replacing with a quality part solved the problem for me.
All fixed, finally. After extensive research and reading Mecha's wise words in this topic and Ken Lawton's in another topic I decided jump earth ground to logic ground and all the interference went away
actually, I said that. but more power to you.
