whats the deal with using a tv as an arcade monitor?
Interesting, but they don't seem to have a 25"... But man do I like the idea of some of those monster sizes... :)
the universal chassis will fit tube sizes 14"-38". Just tell them the size of the tube, the size of the neck, the number of pins on the neck, and whether you need low impedance or high impedance....
Just buy a chassis from 8-liners and be done with it.
During my calls, I found that the Alva chassis were on average about $15 cheaper than the 8liners chassis.
And Ken has stated that it is the exact same chassis...
That's great to know! When I had emailed him, he responded only with Std. Res. details, so I assumed that was all I could get... I am wrong once again and happy about it... :)
Call them. reference the model on that page...
I wonder how hard it would be to find a 19" tv in the wild that would match that universal chassis? Are newer or older 19" tv's more likely to work?
I think any 19" TV you find built since 1990 will work fine...
On another forum I was told that Jen shin makes a universal medium Res chassis but could not find it anywhere. Does anyone know were to get one or a provider that sells Jen shin chassis?
I've built lots of cabinets using a regualar TV. Works great, easy to do and it's cheap.
I wish someone would do a web page or youtube video or something. With tubes no longer available this may be the most viable option but I wouldn't know where to start.
I think I'm going to go down that route with the TV's that I've picked up that aren't suitable for use with a Universal Chassis. So far I've got 3 of them with odd ball tubes, so this is a perfect option.
I'm sorry. I was just admiring your avatar. What were you saying? :)
besides the two sites mentioned does anyone else sell a universal chassis? im still looking for a medium res universal chassis. i emailed both sites and havent got a reply yet
If you go back and look, you'll see I said to CALL Alva...
thought i would be easier since i didnt have the tube infront of me at work for the specs. guess ill call after i pull it apart
What about this converter, has anyone used this? I've never seen one that requires an external power supply before, that would make three plugs for one game....
http://www.jammaboards.com/store/cv-04-rgb-to-ntsc-pal-tv-converter-pcb/prod_253.html
I've never seen a small (under 32 inches) CRT TV that has S-Video inputs. I mean, I've never seen one that has the traditional monitor shape, just ones that are flat screened CRTs. I'm sure they are cheap on CL if I ever have to look, though...
What about this? Could this be used to get S-Video quality video to a TV that just has composite inputs?
http://www.amazon.com/RiteAV-Svideo-Composite-Female-Adapter/dp/B000V1PB3Y
You guys are making a much bigger deal out of using a universal chassis than it is.
All you do is find an older 19" tv, take the back off, and discharge it, then pull the neckboard off. Count the number of pins. There's only 2 flavors - 8 pin (small) and 10 pin (big- like g07's and 4900s used).
Next, find the 4 wires that run from the chassis to the yoke (not yolk like an egg, yoke, like you put around a horses neck for him to pull a plow). There's some variation of the colors, but they are two seperate windings. Unplug these wires from the tv chassis. Take an ohmmeter and measure both sets. If you get infinite or open resistance, you've got one wire from each set.
Write these numbers down. If you have an arcade monitor you can repeat the process on it - if the numbers match, unscrew the tube from your tv, and swap it into your arcade monitor. No yoke swapping required. If it doesn't match, then call alva or 8liners and tell them what you need. They'll want to know the tube size, number of pins on the neck, and the impedance of the yoke (the 2 numbers you wrote down earlier).
They'll send you a replacement chassis.
Once you get your replacement chassis, remove the old tube and chassis and bolt your tv tube into your old monitor's frame, and screw the new chassis to the frame. Connect up the yoke, and the new deguass strap and adapt the power supply and video wiring to your cabinet, and attatch the HV lead and your done.
If you don't have a frame from an old monitor, Bob Roberts does - i think he gets 15 bucks a piece for them. Goodwill has 19" tv's all day long for 20 bucks, and the chassis runs what? 75 or 80? So you end up with a no burn tube, and a new chassis for 125.00 or so.
I've got 2 or 3 of them that i've built up like that, and i love them, the picture is fanstastic - as good as any rebuilt monitor i've seen, if not better. Plus, if you look around a bit, you can get a nice dark tube, and they really pop colorwise.
Shavenyak - if you need help sometime let me know, i'll help you put one together. Its really pretty easy.
Can those newer style flat crt's be used? Like this one?
agdwd2ltYWdlchELEglGaWxlQ2FjaGUYvudYDA
