These are the only pics I have of it right now. We are in the process of packing, so it's a little cluttered. Where it says Sharp is a panel covering the volume, channel and other buttons. In the middle bottom, there is a door that says "game" on it. That door is where the NES carts load in to. The insides are a bit different than your standard NES, too. It does use the standard 72 pin connector, so it can get the flashing issue, but it's easy enough to replace. The main board itself is much larger than a standard NES board.
The two buttons on the bottom left are power and reset for the NES. Unlike the standard NES, they are not spring loaded buttons, but rather more like a TV face button.
and it comes with black controllers:
Mine is missing the remote control that came with them originally. But I have a standard universal programmed to it, and when I hit source the NES turns on or off... very cool.
Usually the feet are broken off, or the doors are missing. One in that condition but still working would probably run about $150, unless you find one "in the wild" where someone doesn't know what they have.
