mr.fixit
what is a lv2000 i just got into color vector and what is it i know its a low voltage power supply, is it worth it? how does it hook up? where do u place it? etc is it recomended for longer life?
Once done, they would get another 3-6 months before the heat/voltage would do it again.
ok, guys i will install one thanks , where can i get said device cheap? also if any one has a gravitar i would apreciate it if they could measure the deflection voltages comming from the pcb yellow and orange wire going to monitor and set your meter to 5 volt scale dc and tell me the range cause i get 3 volts peak and i was told its supposed to be -.3 to.3 and im on the right scale, dont want to hurt my new monitor repaired by slackmoe
