What would you do? Cracked plexi - switch to lexan?
Toph
Arizona
So I built my CP and cut my plexi and all looked great. Got the button holes drilled out and the security screw holes. Got my artwork and I was ready for assembly. When I separated the 2 pieces of plexi after drilling the security screw holes, both layers cracked in different places. The screw holes cracked out to the edge. I'll still use of the the layers to go under the overlay, but what would you guys do for the top piece I have to re-do? Take another shot at the plexi for it's clarity and durability? Or switch to Lexan since it's less likely to crack? I've never worked with Lexan but I've read it's not as clear and is much more easily scratched, even just by wiping it with a cloth.
I'm sure many of you have worked with both. What would you do for the top layer?
Or... would you just ditch doing a top later all together? I'm building a big blue style cabinet out of a midway cab. Making it a SF2 Tubo cab. I know not all of these had plexi at all after production. So since the CP I made isn't to original SF2 specs, I can't use the stock overlay. So I got the kit from gameongraphix that has an overlay, then cut out vinyl decals for the button and joystick art. So my overlay will have 2 layers of decals. I felt like adding a layer of plexi or Lexan may be a good idea to hide the layers as well.
What do you think? What would you do?
Lexan is way easier to cut and drill but it's soft(comparatively speaking) and will scratch easier than plexi - if you are concerned about that, just something to think about.
FYI - I always use lexan - i've never had it crack or splinter on me.
I'm not sure why you have 2 pieces of plexi on your control panel? Just one over the top of the graphic is fine. The buttons and bolts from the joysticks will keep it in place. Are you trying to protect it from the wood underneath? (unless of course I'm misreading what you are asking)
-----EDIT-----
I would def put a piece over the top of the whole panel because you mentioned putting layers of decals - this will keep them from coming off. I've never seen the lexan get scratched just by wiping - but i'm not aggressive - YMMV :)
Typically plexiglass was put on the control panels to cover old button holes. It was really brought on by converting a cabinet to something else. I can't imagine an operator would put plexi on just to "save" the artwork - that would have been an extra unneeded expense -
so really its unnecessary to to actually have plexi especially if you made the control panel yourself - which presumably does not have extra button holes.
but of course its up to you.
-----EDIT-----
Thanks for the response man. Much appreciate. I did grab some lexan and re-made the top piece. The reason I'm using 2 layers is because I cut out a recess for the dust washer in the woods panel. Since I don't have a sheet metal piece to cover that up, I'm using a piece of plexi, put the overlay on that, and now covering it all with a piece of lexan. Hopefully I get a chance to assemble it tonight and can upload some pics.
Thank you for not putting your dust washer on top.
