Pac-Fan
Spotted this on a local CL, and it's the same cab I have 2 of (minus the massive 36" wide control panel bolted to a 21" wide base cab)
http://minneapolis.craigslist.org/dak/ele/3141529783.html
These cabs are a bit bigger than a mini and smaller than a full size. Who made these originally?
They're 21" ID (22.5" outside) wide, about 5' tall -- no marquee, exactly 24" deep, and have a monitor board that is exactly 21x21 so you can rotate it for horizontal or vertical (but have to change out the frame accordingly since there is no bump out).
They have brown, 13/16" wide T-molding and wood grain formica sides. But they're definitely not home built, my two are exactly the same in every way other than the slight pattern difference in the formica.
The speaker is a 4" round hole with a 6x9 Sega Frogger style oval perforated cover (or Round 8") and faces the player just above the glass.
