What type of monitor is this?
scottnagle
New Jersey
I have a Ms. Pac-Man arcade cabinet.
I want to put a cap kit on it.
What brand of monitor is this? see pics (There is an RCA sticker, but a paper label says "Electrohome 19" color monitor".
The board at the bottom of the monitor is what you need to take a picture of.
But probably a G07.
What was the tip off? I can't see crap in those pictures.
the transistor number, the two resistors in the corner, the deflection ic heat sinks, and many other things gave it away, but i have seen thousands of monitors so i don't know everything but i do know alot of them.;)
Well that is a WG K-4900 chassis but the monitor frame is not. The frame is an Electrohome, probably a G07. Are the G07 tube and yoke compatible with the 4900 or did someone transplant a WG K-4900 tube yoke and chassis into a G07 frame?
The tube is probably compatible, I wouldn't risk it on the yoke. Always use the original yoke.
That's a Wells 19 inch 4900 monitor for sure.
Midway mislabeled thousands of monitors with that Electrohome controls layout decal. I see those mislabels all the time. Very common occurance.
