What tools do i need for sayno ez20 repair?
DKJR
Iowa City, Iowa
I now know that i need to adjust my h hold to fix my problem. What tools or tool do i need to do this with so its safe. if some one could give me a link to purchase or a item number to radioshack, cause my radioshack guys are not helpful. Thanks for the help in advance.
DKJR
can i use that screw driver when its on or will i get fried? and should the tweaker ur talking about be insulated or plastic? sorry for all the questions
I use a standard plastic handle metal blade tweaker screwdriver. For best results you will need to have the moniter powered up. You can certainly use a plastic tweaker screwdriver if you wish, but it is not required for safety.
I use my hand to adjust the H hold on the chassis. Just stay clear of the anode wire and use a flash light so you aim your hand to the pot. If you kill or shock yourself in the process I take no responsibility. :)
Electrical tape a small screwdriver so the very tip is only showing, enough to turn the pot so if you drop it on your chassis it more then likely wont damage anything.
If this is in a game that was working fine before and now you need to tweak it you more then likely have a cap going out in that section.
