What size Trackball ??
Quazimoto
Long Island::NY
What size trackballs are you guys using for the 60/1 multi??? 2 1/4 happs @$70 a pop??? Or you using left over 3 inchers taken out of other games??? IE (older golden tees,bowling etc)
It depends on the CP. If the CP needs a 3", then use a 3". The problem is that the 60/1 will not work with some older trackballs without an upgrade or special adapter.
If you want a new 2-1/4" trackball, Arcadeshop sells an Imperial for $49 that I've used before. of course, I did have one out of the six I've tried that didn't work with the 60, but did work with Centipede. of course, the replacement they sent did work, and it was the same brand...
