What Sharp Monitor is this? And can I get a cap kit for it?
ArcadeCited
Pulled from a Hydro Thunder, clearly it was a replacement monitor as it was produced in 2002, my Hydro Thunder was produced in 1999. What sharpimage monitor is this? And is it possible to buy a cap kit for it? Or will I have to buy the caps separately.
No idea what model that is. Is there a label on the chassis or on the monitor frame? Yes, Arcade Parts and Repair sells kits. Just need to know which model you have
If you email/pm security001 with a complete list of caps he can make a kit for you if a kit isn't already available. Had him do it once for a Panasonic color pilot tv from the 80's. Probably won't be able to source quality capacitors cheaper yourself
Edit also next time post this in the monitor section as well, you'll get more help that way
