What other shooters are JAMMA + ?
SgtSmackaho
Michigan
So thinking about picking up an Atari Area 51 Site 4 and was wondering what other shooter PCB's are easily swappable. Is this a good cab to have around to swap shooters or should I look for a different cab?
What is the difference between JAMMA and JAMMA +?
Really?
No one?
Just wondering if Lethal enforcers and other Jamma shooters will work in this cab...
I've got an Area 51 Site 4, which I'm running an original Area 51/Maximum Force board in. I plan to try Lethal Enforcers when I get around to finding that board (in my shed), as well as maybe picking up a Police Trainer. I assume they'll work, but I haven't tried. There's lots of games that should work... JAMMA+ just means it's a JAMMA board, plus one or more extra connectors (for the guns).
DogP
I really don't think it's that simple. Lethal enforcers is a Konami game and Area 51 wiring is unique so it probably won't be an easy swap.
I know HOTD can be swapped out with Virtua Cop 2 since I tried it. They're both model 2 hardware but even that was a pain in the ass to do....
Here's a thread about people swapping stuff between shooter games. I've been on a Lethal Enforcers kick today after starting the process of re-capping that pesky Konami audio module.
http://forums.arcade-museum.com/showthread.php?t=81904
DUDE
I totally didnt see a LE cab while I was there...
Prob busy drooling over all the other goodies LOL
Anywhoo PM me if you are looking to make some room!
I scored a new pad with a sweet basement, time to fill it up!
What do you mean? Both LE and Area51 are JAMMA... do you mean they have different gun connectors? I believe both use compatible guns, though they may need a wiring adapter built if they have different connectors.
DogP
DogP
According to klov Area 51 is unique but maybe that is a mistake. If Area 51 and LE are both jamma wired then I would think the swap would be no problem. The only issue may be like you said about the guns but should be doable.
DUDE
Will do. I've been kicking around the idea of selling a few games but nothing is set in stone yet.
