Is the bottom flush with the laminate? If you strip the laminate and the bottom is flush, that will be noticeable when you go to put new laminate on. You may want to relaminate over the old laminate if that is the case, but then you will have a T molding issue. Maybe you can get a wider T molding if you go this route.... I am not sure on all of the sizes available.
