spoonman
I was wondering if you could fit a normal shelf mounted 19" monitor in this cab withno real modifications needed. Something like a g07 shelf mount, or wg7k
you can fit a go7 or other monitor as long as you have a vertical monitor frame. then you just drill holes in the monitor shelf and bolt it in. i had one in my dk many years ago.
when i had the non sanyo monitor in my dk it was jamma wired with clays multijamma in it with dk, dkjr, dk3, 48in1 all with nintendo to jamma adapters.??? i thought other monitors would not work with the nintendo stuff because nintendo used inverted video or something?
I was thinking i can get a nintendo cab and make it a multi. I wanted to put an arcade monitor in it and i have a couple shelf mount ones kicking around i could use.
Maybe i can find a sanyo frame or other vert frame and transplant my tube and chasis to that.
have a dkjr with an arcadeshop multi in it. running a g07 vertical frame and it works great. I dont know of any shelf mount monitors that will work (even horz sanyos wont fit)
Sanyo monitors only came in one type of frame,not counting the early box type.
They work for either vert or horiz mounting.
and I present to you a photo of a factory shelf mount sanyo out of a dig dug
