What monitor is this?
drewscruis
Eden, New York
I know it's a wells, just no identifying marks on it to narrow it down. Here are some pics
WGM2520 = U2000 (25", obviously)
That cab came with a shelf-mount K7000 originally, so it's been hacked in to the original frame.
a U2000 in need of a good cleaning, cap kit, and width coil...;)
Yep needs a flyback also I think. I hear a snap/click and the whole image gets funky for a sec. So I'll just rebuild the whole thing some day.
there is no reason to change that width coil.
glue it back down and save the money.
i see many like that and they all work fine after being glued.
the U2000 can be a tricky chassis to get fixed.
make sure you re-flow all the big or power resisters and anything else that carry's a lot of heat.
with all the issues you describe, a cap kit and fly are a must.
i would also get that tube checked, the K7000 tubes that came in KONMI cabs were not good tubes and can have focus and color issues.
if you hit a brick wall or need it repaired, your welcome to send it in.
i also stock all the parts you need.
Peace
Buffett
Color and focus are spot on. Just every now and again you hear a tick/arc noise the screen shudders for a sec and goes back to normal. I haven't played it since it started doing that. Trying to get some customer boards back in their hands before I touch this
