What monitor is this? Need a chassis
Stryker28
Donor 2012-2013
Hanover, Pennsylvania
This monitor came with a extra MK2 cab I bough a while ago but it did not have a chassis. I do not know anything about monitors so maybe someone can tell me what type it is so I can find a chassis for it. If you need more pics of it to determine what it is let me know.
This was on the back of the monitor itself
This one was on the frame
The yoke should have a label that says 009A2988-001, right?
If so, then it's just like the label says: 25" K7400 (standard-res). You can also use a U2000 (standard-res) or U5000 (dual-res) with that tube...
Any idea on where to find a chassis for it? Thanks for the info on the monitor. Like I said I do not know a thing about them.
I just rejuved 2 of those exact tubes for a local guy the other night at it had 2 different chassis' on it. One of them may have been a neotec as well.
for the record it uses adapter 23 for the 467. It wasn't in my manual (the tube is too new I think) but I found an updated manual online.
I should have said the 7400/2000/5000 will work with that YOKE I mentioned. The tube may work with other chassis if it has a different yoke...
The wtb/for-sale forums here, ebay, wherever. You can probably buy a universal chassis replacement from alva amusements or 8liners also if you had to...
