What monitor is in a Virtua Racing U/R?
alejandromad
Las Vegas, Nevada
Manual only says "26 inch". No indication of vendor.
I need to replace the one missing from the game and would like to be sure what's an acceptable monitor for that purpose.
Thanks!
You should be able to put in anything that's between a 25"-27" and supports medium resolution. The original monitor would have probably been a Nanao MS8.
I don't know if the factory used the same monitor in an UR as the SD, but I got a monitor from a VR SD, which was a 25" WG K8000. But yeah, any 25" medium res should do it.
DogP
there was another Sanwa monitor that Sega used as well. got two of them in our Daytona twin, I would suspect that there's a chance those would've cropped up in Virtua Racing as well.
you'll have to grab some pictures and post and someone here can ID it for you, or you can try it yourself here: http://arcadecontrols.com/BBBB/monitor.html
