WETHEREDS
I have a 19" with a Wei-Ya 2620H chassis that I recently installed in a cocktail. When the monitor is laid down as seen in the Cocktail_Monitor jpg I get an excellent image as seen in DK_Good jpg.
But when I move the cocktail top assy with monitor to put it back into the cocktail body, I can see a bloom start at the bottom right corner and get worse as it move into the cocktail body as seen in the DK_bad jpg.
At first I thought it was ferrous metal. So I removed the CPs, coin door and anything else metal I could find. No difference. I then added the shield to the monitor and plugged in degauss pins on the chassis. No difference.
So it must be the tube right? Something loose inside?
Any advice or suggestions would be appreciated.
Thanks.
Thanks.
