What is this on my K7000?
Kyrosfear
Donor 4 years: 2012, 2018, 2020, 2025
Pennsylvania
Gentlemen,
Can someone tell me what this vertically mounted board on my K7000 chassis is?
Thank you.
it's one of several different pincushion correction boards found on some models.
if there's a cap on it i would replace it.
you may even try running the chassis without it. there have been reports of it not being needed at all.
as it was an add-on from the factory that is not documented.
Peace
Buffet
Buffett,
Thanks for all of your help. This chassis already needs a cap kit, so I am going to remove it and see what happens.
Those were "typically" found on the 27" and up versions.
Unusual (for me at least) to see one on a 25" chassis.
Might explain why it's not very populated like most others though.
Ahh! I just rebuilt a 25" k7000 chassis that has header pins on it.. Usually the holes aren't populated.. Figured it was for a pin pcb, but never saw one before. Mine didnt need it
I was just going to msg you the URL to this thread. Now we know!
I just did this 27" one and I changed the caps on that board.
Okay, so this chassis needed a cap kit anyway. I took this pincushion off and tried to run the monitor without it following the cap kit. Vertical collapse. Put the board back on the chassis, works fine. I suppose it will stay put now. Thanks guys.
