Not the dumbest thing I've done.. but the most recent.. Put a rom in backwards, powered up.. and saw flashing under the label (like an LED) as it fried..
That was cool..
@andrewb Me neither..Holy shit, what game was that?
I was not aware they could fry to the point of generating light.
I imagine that could happen if the power went into the signal line. The lines that feed that die for the actual ROM are like mini fuses so they would glow before they vaporized.Not the dumbest thing I've done.. but the most recent.. Put a rom in backwards, powered up.. and saw flashing under the label (like an LED) as it fried..
That was cool..
been there, done thatNecked a monitor while removing the Taito monitor frame
Oww, that hurts just to look at.Apart from frying a perfectly good DK board, then doing the same thing to my spare 5 minutes later, then realising I'd plugged the wrong wire into the wrong place both times....
Three months ago, I was carrying a WG6100 monitor across my garage. My feet tangled up in the garden hose that I'd stupidly dumped there the day before. Felt myself falling forwards, instinct stepped in and I held the monitor firm, which accelerated my fall face first onto a shelving unit.
Put my front teeth right through my upper lip. 12 stitches inside the lip, 3 on the outside. It's healed up pretty well now, but by Jimminy, it was a mess.
Not a scratch on the monitor though, so I console myself by regarding the experience as a win overall. A busted lip and a busted 6100 would have been truly devastating. I can live with the scar.
Here's the least graphic pic I have just after the stitches went in.
you brought back a memory of a gottlieb dragon pinball I had. I was all done repairing it and was doing final adjustments of scoring switches when my adjustment tool accidently bumped the lamp circuit. it blew out the spider chip on the board and required a replacement. (I was done!!! not anymore)I shorted a transistor while adjusting the pop bumper switch on a Black Knight, my switch adjuster accidentally touched one of the lamps wire.
So wrapped my switch adjuster with electrical tape to help prevent that but I try to only do switch adjustments with the machine off. Takes a bit longer to get things dialed in but not as long as it takes to repair the board.
Non arcade related but I did once manage to get flames to shoot out of a buck-boost converter IC. I'm not sure what I did, was doing some tests on it in college when I noticed the output voltage suddenly dropped. Next thing I know an actual jet of flame shot out as I was cutting the power. So basically taught me to immediately cut the power if something doesn't look right.
Ah college. Another memory.I shorted a transistor while adjusting the pop bumper switch on a Black Knight, my switch adjuster accidentally touched one of the lamps wire.
