What is CR# for a 3708B22?
WETHEREDS
Central NY, New York
I cannot find a 3708B22 Tube listed on the bkprecision CRT Chart.
Does anyone know the CR number for this tube?
Thanks.
Are you sure you recorded the number correctly? It doesn't look right, since the first string of numbers is usually the tube size. I would guess that your actual tube number is 370AB22...
No, really, the sticker on the tube - 3708B22 - look at the picture.
Ok just cross referenced it with another CRT adapter type. A promax adapter A8 is used on this tube which is the same pinout of a CR23.
