What if I had a Monitor that required a Isolation Transformer and...
Tighe
Richmondville, New York
I just got a Capcom Vs SNK in a corner cut Dynamo cabinet with a Zenith K7000 monitor. The monitor says it requires an isolation transformer. I can't quite see the PS, but what would happen if it were hooked up to direct power? would I see slight a waterfall effect on the monitor?
No... you'd see nothing, because components would blow (assuming everything is grounded properly... and if not grounded properly, you'd see stars if you touched it ;) ).
DogP
It has a transformer
I just couldn't see it because it was hidden by the monitor, when I pulled it out there it was.
DogP
I myself like the ' seeing stars ' part.... put a whole new twist to the star background in Galaga. ;) lol
