What flybacks are available for classic monitors?
RussMyers
Harrisburg, Pennsylvania
What replacement flybacks are available for classic monitors?
WG 4600
WG 4900
EH G05
EH G07
EH K7000
Sanyo 20EZ
Sharp XM2001
Any others?
Anyone trying to repro any of the unavailable ones?
RM
WG 4600
WG 4900 - ChadE at ArcadeCup - repro coming online?
WG K7000 - these are available (all models?)
WG 6100 XY
EH G05
EH G07 - these are available
EH G08 XY
Sanyo 20EZ
Sharp XM2001
Cinematronics XY
RM
OK, so replacement width coils and flybacks are unavailable for either the 4600 or 4900, but new 4900 flybacks may soon be available from ChadE.
RussM
RussM
I read you can use the width coil off of a K7000 on the K4600. You just hang it off the side of the chassis with wire instead of mounting to the original location.
WG 4600
WG 6100 XY
EH G05
EH G08 XY
Sanyo 20EZ
Sharp XM2001
Cinematronics XY
RM
WG 6100 XY - are available
Sanyo 20EZ - are available
Reproduction flybacks have been available for the Sanyo monitors for a couple of years now.
Unfortunately, the Nintendo SHARP monitors do not have flybacks available.
OK, is this now accurate?
WG 4600 - No replacement flyback or width coil available (Width coil from WG 7000 may work)
WG 4900 - Replacement flyback (coming soon); No replacement width coil available (Width coil from WG 7000 may work)
WG 7000 - Replacement flyback and width coil both available
WG 6100 XY - Replacement flyback available
EH G05 - No replacement flyback available
EH G07 - Replacement flyback and width coil both available
EH G08 XY - No replacement flyback available
Sanyo 20EZ - Replacement flyback available; No Replacement width coil available
Sharp XM2001 - No replacement flyback or width coil available
Cinematronics XY - No replacement flyback available (some NOS still available)
Ampliphone XY - Replacement flyback available
RM
Sanyo 20EZ - Replacement flyback available; No Replacement width coil both available
RM
Arcadeshop sells NOS Cinematronics flybacks for $45. So there is technically a replacement available. :)
Also, your Sanyo comment has "both" in it and should not.
Dagnabbit.
Amplifone XY - Replacement flyback available
RM
Dagnabbit.
RM
Ok, Forum member Chris25810 says that the K7000 width coil can be used, so you can dump the "may work".
http://forums.arcade-museum.com/showthread.php?t=83441
It also reads like the 4900 can use the 7000's coil because it is the same but has the ferrite shield. Chris indicates that you just don't want to use a non-shielded one on a 7000 because it won't last.
You can add Sanyo 20-Z2AW to the list, and place it firmly in the "No replacement flyback available" category. Most of the Z2AW's parts are interchangeable with the EZV, but not the flybacks (God only knows why).
