What Exactly is a Cap Kit?
Its a bunch of new Capacitors that will replace old capacitors, and each board has a specific 'kit' that will go to it. Like a power supply may have 5 specific capacitors that it needs to function, therefore getting a 'kit' for it will give you all five of those capacitors brand new. At which point you have to remove the old ones and put the new ones in.
Hehehe.
OK, so, real answer, with explanation:
Electrolytic capacitors fail over time and weaken with age. There are several reasons for this, that I won't go into here. Safe to say, a thirty year old electrolytic isn't usually in as great a shape as it should be - it might still be working, but not as well as it should. A common repair, then, is to simply replace all of them in one go. For people like me that fix lots of monitors, I buy capacitors in bulk by value. But for someone that only needs to do a few monitors, it's much simpler to buy a "kit" of replacement capacitors for a givin monitor. Each model of monitor uses different values of caps and in different quantities - so a kit for a G07 won't have all the necessary parts for a 4600. But, assuming you order the right kit, it should contain all (or most) of the commonly stressed parts in the monitor.
A cap kit will fix things like warped and distorted picture, folded over picture, washed out colors, touchy sync, etc.
Further repairs for completely dead monitors usually include a cap kit - since while you've got it on the bench, there is no reason why not to re-cap it. The Electrohome G07, for example, is well known for it's blown flybacks. So, you can get a flyback kit with the flyback, HOT, fuses, and all the caps - this fixes like 90% of dead G07's...
-Ian
You dudes crack me up!
This is a very fun forum. ;)
If you notice, we generally wait to do the silly stuff after a question has been answered... But not always.
I'm just proud of all the people that joined in! :D
andy capp collection book
