What exactly does the Hi-Score Duration [Hours] setting do in Zoo Keeper?
I am curious what the "Hi-Score Duration [Hours]" setting does in Zoo Keeper. It's not quite clear in the manual. It says the left column of scores is affected. These are the all time high-scores. The column on the right are the daily high scores, right? The manual says the right column remains the same. What does that mean?
So, does this mean the left column scores start disappearing after X hours and depending on the setting? So, if it's set to the default of 14 does that mean that after 14 hours of being on the scores on the left go away?
What happens if you set it to "0"? Does it mean they don't go away, ever?
