what dyno is this?
partygt
California
picked up a odd dynamo. was wondering which it was and can you rotate the monitor to vert?
Looks like a variation of the Dynamo HS-27.
Seen one before but this one looks like it's been shortened at the bottom.
looks like hs27. You should be able to rotate it and raise it up if to a more vertical position if you don't want to use the trackball position. I have not moved one, but I would think its a matter of just moving a support bracket. MAybe the plex will need to be replaced.
I think there are some parts that might be in the bottom of cab to convert it. I just don't know if they are used or swapped in the up or down position. The one I had was up and they were in the bottom.
Yep. That's what the pre-drilled holes are on the side. They are even seen in the pics in the original post. Don't remember how to move it around tho and whether you just use the existing hardware.
I like the monitor where it is! Like pacman position. Looked like it may rotate. I just didnt want to pull apart unless i was sure. Thx for info.
