What do you call the part that...
viewsonix
Virginia
What do you call the part that goes around the hole in the cabinet that the coin doors screw into? I'm assuming it's a steel coin door bezel or coin door frame? Is that correct?
I ask because I need to put coin doors on my project (to fill the big hole in the cabinet)
and I was able to pick up some coin doors with the mechanics for cheap, but they did not include the frame/bezel that the 2 individual doors attach onto.
Is there a good place to buy just this part for cheap? I haven't seen anyone advertise just the frame / mount /whatchamacallit before.....
Post a pic of the cab and the coin door in question. And it's a frame...
Here are the doors, I have 2 sets as you can see.
The opening is the normal up/down kind you see alot of, it's a Star Wars Upright cabinet.
I think it would be simpler to track down an entire over/under coin door assembly instead of finding remnants. Still, if its the frame you seek, then it would be called the over/under coin door frame.
It may have another name but that's what most tend to call it.
I will be you 8 out of 10 KLOVrs have spares just sitting in their garages or storage units.
I'm surprised you actually found the doors by themselves. Usually people remove the whole assembly at once. Those doors are standard over under coin doors. You might have more luck finding the whole assembly than you would just the frame.
Here's one that's being sold in the for sale section, and here's one on ebay which is about $25 shipped.
I have just the frames. PM me if you are interested.
Every time Aaron mentions he has a part someone needs, I picture him living on the set of Sanford and Son.
Not all doors match all frames so you might check to see if the hinges on your doors have 3 or 4 holes and the spacing between them. The Happ and Coinco doors are different. Been there. Might be a lot easier to just grab a used set. Post your location. I've got several sets here at the house. I'm sure others do as well.
