What do I need in a router for T-Molding
tevans333
Bloomfield, Michigan
I have no wood working skills what so ever, but I need to cut the slits in some pieces for some T-molding. I am going to pick up a router, but have no idea what the different types are. Can anyone point me in the right direction as to what to look for? I see fixed base, plunge, table...I'm lost LOL.
A basic plunge router with a slot cutter should work fine. Go to Lowes or Home Depot and look in the sale section. They always have open box or older models for a lot cheaper than the others. You will have to order the slot cutter online though.
Thanks, so a plunge is different than a fixed base? I saw a fixed base for about half the price as the cheapest plungge but wasn't sure it would do the job.
A plunge is better in my opinion because it is more versatile. If you start using a router more you will learn to appreciate the better functionality.
They usually have more HP and higher RPM.
Here's a link to where I get my slot cutters from. They are probably the cheapest place around. Decent quality too. I wouldn't recommend it for everyday use but for what you're using it for it should be more than adequate.
http://www.mlcswoodworking.com/orderstatus/html/smarthtml/pages/bt_slot.html#anchor_slotct3w
Most woodworking forums I've browsed regard the MLCS stuff fairly well. It's not top notch, but it's good stuff, unlike how most regard router bits from Harbor Freight. I've gotten some great stuff from there, especially considering the prices and free shipping.
Get the 1/16" for cutting the slot for 3/4" t-molding.
i buy porter cable routers, probably overkill for T-molding as well. Get a 1/16" whiteside slot cutter and arbor, works well and reasonably priced.
Yep...I am a dremel junky....
Got a lot of the dremel attachments - any excuse for more tools!
They can be found many places, but not for a decent price.
If at all possible, you want 1/2" shaft. If your router takes both, might as well buy 1/2" from MLCS or mail order - the prices are nearly the same for either size shaft. 1/2" feels a bit more solid and stable.
