what cab is the same as a dedicated Ghost and Goblins??
RayWest
Westfield, Massachusetts
I have a complete GnG kit and wanted to put it in a GnG cab. Are there any other cabs that I can use that are exactly the same as a dedicated Ghosts and Goblins???
Ray,
I don't think they came dedicated... kits only. That said, most games from that era came in Dynamo cabs.
Ray,
Yeah they did come dedicated. It came in a horribly heavy purple cabinet made of melamine-coated fiberboard. But as to your question of what other games came in that cab? None that I know of.
A 98% match cab is Commando! The kit will fit it, although:
The marquee will be a hair short...either use a couple flat thumbtacks to help hold it up under the bracket, or do what I did and use an old AD marquee bracket.
The control panel for Commando, although the same size, is a little different shape - it bends in at the bottom instead of staying out ala Williams style. Also GnG's control panel the bottoms are even with the joystick, on Commando the buttons are slightly above the joystick line.
Command is an upright cab, but this didn't stop my from cutting a slot to make it a horizontal cab.
The inside is identical, as well as I think the wiring harness/pinout is the same as well (verify that).
http://www.junknet.net/arcade/?g2_itemId=6817&g2_page=1
