What are you using to program GAL's?
Riptor
Leonartown, Maryland
Im looking to see if any of my programmers will do GAL16V8, 20V8. I already know my willem GQ-4X wont do them. I also have a pocket programmer 3 which doesnt appear to do them either. My last programmer is a Data IO 29B with Unipak 2B. This one im not sure of.
I dont have an immediate need to program any but would like to be able to if ever needed. If the 29B wont do them does anyone have a suggestion for a programmer that will? PAL's would be a plus as well.
I currently use an Advin U84+. Quite easy to use, quite reliable but quite expensive.
I used to use a 29B with the unipak adapter. Worked ok but was awkward to use and not real peppy.
I also own an Xeltek Superpro 2000+... biggest piece of crap I ever purchased.
Ed
I'm using a TopMax, that's a bit overkill if you just want to program PAL/GALs ;)
- James
I once had two different Xeltek's, Superpro I & II, as they were worthless crap. IIRC one popped a drive transistor in the first days the other couldn't actually program PROMs as it was supposed to. Sounds like quality is still their middle name.
- James
Im just probing to see if there are any cheap programmers in the $100-$200 range that will do pal/gal's. Im thinking probably not but figured I would ask.
So the Unipak 2B will do them? I have mine running great on XP. Yeah its slow programming but I typically only use it for proms.
We use a Xeltek Superpro 580U here at work, it replaced the Willem we blew up. Nice programmer, actually. It'll do the GAL16V8 no problem.
- James
I'll 2nd that. I hated my Xeltek and was glad the day that was gone. POS.
Like jrok I also use a topmax but is overkill. I just wish now I would have gotten the
USB one versus the parallel port one.
It looks like the 29B with the correct version of software and the LogicPak (http://commons.wikimedia.org/wiki/File:Data_IO_29B_LogicPak.jpg) and the correct adapter can program these.
I know I have a (or more than one) LogicPak and some adapters. No idea if they are functional. You are welcome to them.
http://arcarc.xmission.com/Test Equ...a-IO Unisite Programmer Software/logicpak.txt
I have never seen Topmax programmers before.
I like the Advin that I use at work but I need a reliable and -affordable- programmer at home.
Checked into that Topmax but it is now obsolete. The replacements - Topmax 2 and Chipmax 2 look pretty nice. I may need to look into those two a little better. I need a programmer that can do old Lattice GAL6001's -- it appears these will do them. My POC Xeltek 2000+ also says it programs GAL6001's... nah, the software bombs everytime you try.
Anybody want to buy a Xeltek? It's guaranteed to look nice on your desk. Won't do anything but sure looks nice.
Definitely post back if you try it... that'd be way better than messing w/ building a Parallel Port adapter by hand.
DogP
Yeah, let us know. I have been eyeballing it for a while.
DogP
I use a TOP2007... think I paid less than $100, uses USB only and works great for most GAL/PAL chips
I will probably pick up a TOP853 in a few weeks.
Jason, is the TOP2007 a better model? I see it cost a little more.
+1 on TopMax... that thing ROCKS... but cost me $500 + tax on closeout at Fry's.
However, I bought me a spare, NIB, off of eBay and it was about $180 shipped. :)
Maybe you can get lucky.
