What are you doing with your 13" g07 chassis?
Griffin
EL CAJON, California
As this little gem is a c28 it seems that finding a 370ESB22/370FVB22 tube is tough other than $300 Commodore 1701/1702 monitors.
Are there any adapter options to go from c28 chassis to c31 or c23 tubes out there, or is that simply not an option?
Do I just make a Flavor Flav neckless out of mine and wear it to arcade conventions?
I can't make out what your question is.. Are you trying to find a tube with a compatible yoke?
Just tube swap in a matching tube and use the original yoke. Mark rings position on tube, remove rings/yoke leaving wedges in place. Slide on GO7 yoke and replace rings.
Yep but finding c28 13" tubes is the issue, I have the matching g07 yoke.
Funny, all the 13" tubes I've found are fat neck CR23 socket tubes and swap in fine. It's the 19" fat neck tubes that I can't find.. all skinny neck CR31s
You're not the only one. Half the shit this dude posts make no sense.
I used to have a sweet little RCA tv that had that tube in it. Not that I would advocate robbing a working one... but I guess it would be preferable to sacrificing a Commodore monitor.
Yep it's difficult to find all of the models out there with the tube. Unfortunately on this particular tube crtdatabase doesn't have many TV models listed
