What am I looking at?
retroACTIVE
KEEDYSVILLE, Maryland
I was just about to put my 19K4915 med res monitor for sale and when I was going over it i looked in the top of the tube, behind the metal banding and it looks like there is a foil cone or something that contours the tube that is flopping around in there....
The monitor actually works fine but I don't like what I am seeing, it doesn't seem right... something has broken loose in the tube...
Anyway... what am I looking at? Tube anatomy to me is gun and phosphorus... I know there is more to it than that. ;P
If you look at the pic you can kind of see the little copper A shaped wire and the "foil" that it is attached to.
It may be one of the springs that hold the faceplate in position against the front of the screen. If the faceplate is wobbling at one corner, I would think that you do not have good color reproduction in that area.
If the monitor is jarred while it is on, do you see an effect on the screen?
I can't really make out what is in the photo.
K
I can't really tell what you're looking at there from the photo - but from your description, it sounds as if something is loose? Can you hear it rattling around?
There is a lot more to the inside of a tube than just the gun and phosphors. Inside the face of the tube is the shadow mask - a mesh plate that helps to prevent an electron beam from hitting the wrong phosphor. This mask is what becomes magnetized and is what you're degaussing with a degaussing coil.
If it's loose, then it'll screw up the colors. It should not be loose - it shouldn't be able to move at all.
-Ian
Sorry for the crappy pic... It's definitely metallic and flopping around.
I'm not going to sell this bad boy as a "working" monitor. I'll strip it and sell off all of the parts... med res monitor - tube.
