what all do i need to change a Vs. to playchoice
punkshere2stay
Donor 2012
fort worth, Texas
i figure my monitor and power supply would work..
so i just need the playchoice single monitor pcb, and single monitor wire harness and games right???
You will need the single monitor PCB with games of course, but your existing Vs. harness will work for the most part, as long as the dips on your motherboard are set to freeplay. That way you don't need to worry about the timer. You'll need a populated PC-10 control panel, or you can do what I did and add 2 buttons to a Vs. CP. If you use my method, you'll need to add wires for the extra 2 buttons.
