That looks very cool!
Any experience with it? How long (in seconds) does the 16k buffer last?
Does someone make a case to put it in? I'd surely short it out eventually this way.
... Altan
I've used it a few times, and I hot-melt glued some cardboard to the bottom to keep from doing too much damage (I really should build a box around, but I'm kinda lazy). The software takes me a bit of bumbling around in each time I try to use it, and it's triggering isn't as rich as the HPs, but I eventually remember how to set the thing up correctly and I get the job done. It did a good job for me when I was completing my understanding of the EL panel controller on the NEO-GEO, and I've used it for work a few times (I work from home and so if I really need to know what's going on with hardware I/O, I'm kind of on my own).
The length of time for the buffer depends on the rest of your settings - at a given sample rate the buffers are smaller than what you'll find in HP analyzers, but not too shabby.
16K samples @ 200 MHz is 0.00008 seconds (that's 80 microseconds).
16K samples @ 100 Mhz is 0.00016 seconds (160 microseconds)
16K samples @ 10 Mhz is 0.0016 seconds (1.6 milliseconds)
16K samples @ 1 Mhz is 0.016 seconds (16 milliseconds)
For most older arcade systems, you don't need to sample at the real high rates (if the clock on the system is 1Mhz, then 4Mhz sampling is going to allow you to see the clock itself pretty well, and everything else will be SLOWER that the clock, and therefore 4Mhz will be just fine).
8 channels is really enough for much of what we do, but 16's even better for some stuff. The board can SAMPLE 32 channels, but only 16 channels have buffers (and connectors). You'd have to do some work and add some chips to make it do 32 signals.
