So this chassis takes a neckboard ground and a chassis ground. You can see the neckboard ground attached but not the chassis ground. (Top right of image post here.) You can see the post is not connected to anything). The neckboard ground and the chassis ground share the same tube strap ground.Below you will see on the left bottom there is a gray connector going on the neck board. That is no longer there. How can I make a new one because that connected to the neck board then ran into a nut along with a black wire from the frame and I guess that is the ground as stupid as I sound or am. Where can I get that grey connector? Thanks
Exactly Jason. And when I sent it out I had that neck board ground but it came back with out it. The way the person who sold it to me had the neck board ground and a wire from the strap , both cut and capped off with a black cap if you could see it. If not I'll put up a picture of how that looked.So this chassis takes a neckboard ground and a chassis ground. You can see the neckboard ground attached but not the chassis ground. (Top right of image post here.) You can see the post is not connected to anything). The neckboard ground and the chassis ground share the same tube strap ground.
Hey can I use alligator clips?So this chassis takes a neckboard ground and a chassis ground. You can see the neckboard ground attached but not the chassis ground. (Top right of image post here.) You can see the post is not connected to anything). The neckboard ground and the chassis ground share the same tube strap ground.
So now your changing your story and saying you did send it for repair?Great guy! No frills. Degauss works. Beautiful picture
Is that WG really worth 400 with shipping?What. The go7 was sent in?
Monitor or chassis?Is that WG really worth 400 with shipping?
Chassis you have on eBayMonitor or chassis?
Oh. Ebay rapes you on fees so you adjustChassis you have on eBay
hey could i ground the chassis with alligator clipsOh. Ebay rapes you on fees so you adjust
After reading through this thread i feel like grounding my chassis (any machine will do) with nipple clipshey could i ground the chassis with alligator clips
your on mute, muteAfter reading through this thread i feel like grounding my chassis (any machine will do) with nipple clips
Been two weeks waiting for this chassis to come back from Georgia. Holy cowOh. Ebay rapes you on fees so
