What’s better
Below you will see on the left bottom there is a gray connector going on the neck board. That is no longer there. How can I make a new one because that connected to the neck board then ran into a nut along with a black wire from the frame and I guess that is the ground as stupid as I sound or am. Where can I get that grey connector? Thanks
Not sure what the size of the neck board grounding post is, but here is a 1-pin housing that might work:
You will need a .093 female molex pin to go with it. Along with some wire strippers and a molex crimping tool.
This 1-pin housing takes the .062 size pins. I would just order this one and the one above plus a few female pins (in both sizes) for spares in case you mangle 1 or 2.
This way you have both sizes. One of them is bound to work.
Depends on the monitor, but a G07 takes a spade connector for the neck board ground. Most are round, but not all.
But... the ground wire to the neck board comes from the dag. If you sent your chassis out for repair, that ground wire and plug should have stayed with the tube. How could the chassis come back without it? Did you sent the tube & chassis out together for repair? Or did your tube have an "op mod" where the ground wire was cut and wire nutted together, and you sent the chassis with the ground wire pig-tail still attached to the neck board?
This is a good point. Could be a spade connector. However, that existing grey connector in his picture (assuming it is stock) is definitley round.
More pictures would be tremendously helpful but getting the OP to post pictures is like pulling teeth.
Yes, totally get you and that is a round plug. But 15 minutes from now, it will be a G07 they are trying to connect. Just trying to cover some bases. Futile effort, I know....
I still don't understand how a chassis can be sent out for repair and come back with the dag ground plug missing. Doesn't pass the smell test.... :)
Because John took it off as he created some sort of hell for me. Again I have to be cival I was warned, but it came back to me not working. Clicking constantly when plugged in
Yes it was round!! Connected to a round pin
Thank you yeti!!
That is exactly what I need. Then the proper wire so I could crimp them together
Was John there to take this chassis? This gets more confusing...
The plug you reference in your photo should stay with your tube, unless as I previously mentioned, that wire was cut and you sent that end connected to the neck board with the chassis (or John took it)?
If your looking for a straight answer your likely never going to get one
I agree. But due to help from others here, I was able to get my SI cocktail monitor working yesterday. The least I can do is try to help someone else. It's worth a few minutes of my time, even though I think this may be the most impressive prank ever pulled on KLOV.
John took it. I sent that chassis out as seen in the picture. Why would I have touched it. Remember the chassis was working when sent. I only wanted a refurbish due to my OCD. Came back with out it.
