wgm1931 chassis help
kidrivers
Donor 4 years: 2012, 2015, 2017-2018
Missouri
Hi guys, i have a wgm1931 chassis listed for sale on here at the moment. I just picked up a 19" monitor with almost the exact same tube and i tried the 1931 chassis on it, the picture is very narrow horizontally, and i can't adjust it out. I know this chassis needs caps but i don't know if that is my problem here or if the tube isn't correct for this chassis. i just wanted to know if someone could help me find out for sure it this tube is compatible with this chassis. I have heard about checking ohms on the neck pins (i think) to see it the chassis will work but i need to know what to check and what values would be correct for the 1931 chassis. thanks for any help!!!!
is there any way to be sure the yoke is the problem?
