WGK7401 Question
SiLeNtNiNjA1
Farmington Hills, Michigan
I Just picked up a K7401 monitor. Iws working fine, but the image is mirrored. Im fairly sure I can just flip both of the 2 pin connectors coming from the yoke to mirror the image, but im not 100% sure. I figured before I blow up my new monitor, id come on here and ask!
Looking here,
http://homearcade.org/BBBB/yoke.html
I just flip the 2 connectors and im good, but if im wrong, kaboom!!
Thanks!
If it's mirrored left to right just flip the red and blue wire yoke connector near the flyback.
Do it with the power off.
Thanks - it's flipped verticaly, but since you've told me the yoke connectors can be flipped safely, verticle or horizontal dosnt matter - I can flip either :) as long as the connectors are isolating vert from horiz, I'm good :)
Uh, sort of. The red/blue near the flyback needs to stay by the flyback. If you need to flip the image, just rotate that connector on those pins. Don't move it to the spot where the yellow/green is plugged in.
you need to swap the positions of the yellow/green wires by rotating that connector on those pins...
