WGK7000 Picture Issue
craigolof28
New Hampshire
The picture on my WGK7000 is perfect for the most part, but the right side of the picture looks like it's sagging down. I recently capped it but am still getting this problem. I adjusted the picture but the image stays like that no matter what size it is. It isn't a huge issue, I was just wondering what causes this and how it can be fixed. Thanks.
You need to adjust your Horizontal Hold.
It could be a board issue. I have a Capcom Bowling that does the same exact thing. Luckily I only use it as my jamma test board.
Have you tried another board?
Yeah I have plugged other boards into, still get the same results.
Well my good sir, I must applaud you for elimination of that possibly before posting. I am with Zeno here regarding vert/hori hold issues. I know you have tried that already so I would say cap it, but you already have done that as well. I do not want to tell you to just adjust that portion off-screen because I hate half-ass fixes so I must bow-out and let the more knowledgeable gentlemen guide you on your quest. Good luck sir and stay at it.
The way you worded that was all I needed to hear haha thanks for your help guys. I don't know if my sync is on pin 10, I'll check when I get home. Take care.
that is a sync issue.
only use pin 10 on the vidoe input header.
Peace
Buffet
You were correct man. I swear I never know whether I should be happy it's such a simple fix, or be pissed off at myself for not knowing it was an easy fix haha regardless, thanks for the help man.
no prob happy to help.
i have seen that problem so many times i dream about it:D
glad it was a simple fix.
Peace
Buffett
