I have a 90% working WG6100 I will be re-capping. It appears to be pretty stock... no LV kit... the extra "riser" board I've seen on some 6100's isn't there... etc.
It works though there about 1" or so of collapse on the left side of the screen.
I plan on adding a LV6100/LB2000. I am going to order a Bob Roberts cap kit though he offers 4 different versions. I forgot what I bought last time. I already have the transistors that mount to the frame though I was under the impression that I shouldn't replace them unless they're bad... right? Will a single transistor going bad cause the collapse I mention? If so, anyone know which transistor matches up with the left side of the screen (if it even works that way).
Also, which kit should I get? The basic or the basic and added parts kits? Again, I already have the big transistors if needed.
