I took out the monitor and found a few strange things.
-R100 15ohm .5w has been overheated but still reads fine. What might cause this to overheat? I will have to replace the resistor.
-The flyback has a screw out of it. It looks broken off when you pull it out. Sorta melted or snapped in half look.
-The clip of the flyback that goes into the monitor has a small metal plate on it. I have only taken 3 monitors apart now, but I have never seen this before. Is that normal for the 6100 monitor?
The 6 monitor chassis transistors read .5 to 1.9 from the metal body to the chassis. I will have to take some other stuff apart to measure the pins.
Here are some pictures. I will also keep updating a site that might help out someone else as I work to solve my issues.
https://sites.google.com/site/tempestcocktail/
That is a super reply. Thank you for all the information. I am ordering a cap kit and some other things from Bob tonight. Where would you suggest getting a lv2000 kit from?
That is a super reply. Thank you for all the information. I am ordering a cap kit and some other things from Bob tonight. Where would you suggest getting a LV kit from? And what is that small metal plate on the anode cup for?
The five things that look strange to me are: ROM 8 on the game board, Xout on the game board, the 36AC line on the AR2 board, the Sense on the AR2, and the 10.3DC on the AR2.
Xout -1.53 not moving
AR2 Board
Rings Readings
36AC 18.2AC I might be reading this wrong. I took the black probe to the GND ring
and the red probe to the 36AC ring. It reads 37.09AC from the power supply
connector with the red and black probes on the two pins within the connector
from the power block.
10.3DC 12.4DC
