WG6100 REPRO (C)2020 Board Information Needed
divingbuddy
Donor 10 years: 2013-2022
Utah
I came across this repro WG6100 deflection board. I am looking for a parts list and who made this board. I searched KLOV and have not found the information I need. Please help, TIA.
Would an LV2000 work on this board? This is one of the questions I have, and possibly get it working again.
I would assume it pretty much follows the latest OG P314 BOM. However, it seems to already incorporate the linear regulator solution as is.
The LV section components have been removed by side cutters, not de-soldered. This was done before it came to me.
So, clean the holes and add back the missing discretes. The circuit is simple. When testing on the bench, just add + and - input voltages to the unattached board and confirm the regulators are functional. Then worry that the deflection circuitry is working.
If this is a "desbaz" board, then the schematic is likely posted on his website. Go fish.
It was likely a prototype somebody was making that they had issues with.
I say this because they used ground fills on both sides of the board. I have made several 6100 clones and found out the hard way during prototyping that you can't uses ground fill because of capacitance.
What you get is coupling between the drive transistors and the sense resistors. This creates "noisy" vectors that can not be corrected.
The connection has timed out
The server at www.dsbelec.iinet.net.au is taking too long to respond.
  • The site could be temporarily unavailable or too busy. Try again in a few moments.
  • If you are unable to load any pages, check your computer's network connection.
  • If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
You can test it out with some 24V switching supplies and ignore the LV section all together. That will at least let you know if it is worth trying to save.
I can loan you a test setup with heatsink mounted power transistors if you don't want to risk good bottle caps.
The parts were damaged/broken during removal.
I am still in the research mode for board information.
