WG6100 Monitor Hardware/Chassis Screw Sizes
Glitch
Donor 3 years: 2013-2015
Anaheim, California
Had to piece together a 6100 monitor this weekend that was missing most of the hardware and compiled a list before bolting it back into a machine:
Deflection PCB
(2) #8 x 1.25" Sheet Metal Screws (Hex Head)
HV Cage
Cage - (6) #8-32 x 3/8" Machine Screws (Hex Head)
Cage - (1) #8 x 1/4" Sheet Metal Screw (Hex Head)
BU207 Transistor - (2) #6 x 1/2" Sheet Metal Screws (Pan Head)
BU409 Transistor - (1) #5-32 x 1/2" Sheet Metal Screw (Pan Head)
Note: Optional PCB/Frame screws: (4) #8-32 x 3/8" Machine Screws (Hex Head)
2N3792/2N3716 Transistors
(12) #6 x 1/2" Sheet Metal Screws (Pan Head)
Chassis Frame
Classis Floor - (4) #8 x 1/2" Sheet Metal Screws (Hex Head)
Frame Sides - (4) #8-32 x 3/8" Machine Screws (Hex Head)
15PIN Connector Bracket - (2) #8-32 x 3/8" Machine Screws (Hex Head)
Ground wires - (2) #8-32 x 3/8" Machine Screws (Hex Head)
Monitor Tube
Monitor Tab Brackets - (4) 1/4 x 1.00" (w/ washer and lock-washers) Note: Jam nuts mounted in monitor frame
