Update:
I put everything back together and started connecting things one by one.
Deflection board alone: no problems, spot killer on
P100,P600,P700: No fuse blows!
I measured -26V at the 3792, and around +1V on the 3716 on the side of the frame. Spot killer on.
P701: Deflection chatter, same volt readings, spot killer on
P101: Same, spot killer off
Neck connector: Same, 3792 -26V, and 0V to around 3V on the 3716, depending on deflection. I could see the readings go up and down based on the amount of chatter I would hear.
The only thing I have left to connect is the HV cage, which I'm reluctant to do until I verify these readings, as the 3716 doesn't sound right - should be +26V.
